Fuchsia
Pink + Purple == Fuchsia (a new Operating System)
Welcome to Fuchsia! This document has everything you need to get started with Fuchsia.
NOTE: The Fuchsia source includes Zircon, the core platform that underpins Fuchsia. The Fuchsia build process will build Zircon as a side-effect; to work on Zircon only, read and follow Zircon’s Getting Started doc.
Contents
- Prerequisites
- Get the Source
- Build Fuchsia
- Boot Fuchsia
- Explore Fuchsia
- Running tests
- Contribute changes
- Additional helpful documents
Prerequisites
Prepare your build environment (once per build environment)
Debian
sudo apt-get install build-essential curl git python unzip
macOS
- Install Command Line Tools:
xcode-select --install
- In addition to Command Line Tools, you also need to install a recent version of Xcode.
Get the Source
Follow [the instructions to get the Fuchsia source] (Fuchsia Source 官方文档 (英文)) and then return to this document.
Build Fuchsia
Note: A quick overview of the basic build-and-pave workflow can be found [here] → (Build and Pave Quickstart 官方文档 (英文)).
Build
If you added .jiri_root/bin
to your path as part of getting the source code, the fx
command should already be in your path. If not, the command is also available as scripts/fx
fx set x64
fx full-build
The first command selects the build configuration you wish to build and generates the build system itself in an output directory (e.g., out/debug-x64
The second command actually executes the build, transforming the source code in build products. If you modify the source tree, you can do an incremental build by re-running the fx full-build
command alone.
Alternatively, you can use the underlying build system directly.
[optional] Customize Build Environment
By default you will get a x64 debug build. You can skip this section unless you want something else.
Run fset-usage
to see a list of build options. Some examples:
fx set x64 # x64 debug build
fx set arm64 # arm64 debug build
fx set x64 --release # x64 release build
[optional] Accelerate builds with ccache
and goma
ccache
accelerates builds by caching artifacts from previous builds. ccache
is enabled automatically if the CCACHE_DIR
environment variable is set and refers to a directory that exists.
[Googlers only: goma
accelerates builds by distributing compilation across many machines. If you have goma
installed in ~/goma
, it is used by default. It is also used by default in preference to ccache
To override the default behaviors, pass flags to fx set
–ccache # force use of ccache even if goma is available
–no-ccache # disable use of ccache
–no-goma # disable use of goma
Boot Fuchsia
Installing and booting from hardware
To get Fuchsia running on hardware requires using the paver, which these instructions will help you get up and running with.
Boot from QEMU
If you don’t have the supported hardware, you can run Fuchsia under emulation using [QEMU] ->(QEMU 官方文档 (英文)). Fuchsia includes prebuilt binaries for QEMU under buildtools/qemu
The fx run
command will launch Zircon within QEMU, using the locally built disk image:
fx run
There are various flags for fx run
to control QEMU’s configuration:
-m
sets QEMU’s memory size in MB.-g
enables graphics (see below).-N
enables networking (see below).
Use fx run -h
to see all available options.
QEMU tips
ctrl+a x
will exit QEMU in text mode.ctrl+a ?
orctrl+a h
prints all supported commands.
Enabling Graphics
Note: Graphics under QEMU are extremely limited due to a lack of Vulkan support. Only the Zircon UI renders.
To enable graphics under QEMU, add the -g
flag to fx run
fx run -g
Enabling Network
First, configure a virtual interface for QEMU’s use.
Once this is done you can add the -N
and -u
flags to fx run
fx run -N -u $FUCHSIA_SCRIPTS_DIR/start-dhcp-server.sh
The -u
flag runs a script that sets up a local DHCP server and NAT to configure the IPv4 interface and routing.
Explore Fuchsia
When Fuchsia has booted and displays the “$” shell prompt, you can run programs!
For example, to receive deep wisdom, run:
fortune
To shutdown or reboot Fuchsia, use the dm
command:
dm help
dm shutdown
Change some source
Almost everything that exists on a Fuchsia system is stored in a Fuchsia package. A typical development workflow involves re-building and pushing Fuchsia packages to a development device or QEMU virtual device.
Make a change to the rolldice binary in garnet/bin/rolldice/src/main.rs
In a separate shell, start the development update server, if it isn’t already running:
fx serve -v
Re-build and push the rolldice package to a running Fuchsia device with:
fx build-push rolldice
From a shell prompt on the Fuchsia device, run the updated package with:
run rolldice
Select a tab
Fuchsia shows multiple tabs after booting with graphics enabled. The currently selected tab is highlighted in yellow at the top of the screen. You can switch to the next tab using Alt-Tab on the keyboard.
- Tab zero is the console and displays the boot and component log.
- Tabs 1, 2 and 3 contain shells.
- Tabs 4 and higher contain components you’ve launched.
Note: to select tabs, you may need to enter “console mode”. See the next section for details.
Launch a graphical component
QEMU does not support Vulkan and therefore cannot run our graphics stack.
Most graphical components in Fuchsia use the Mozart system compositor. You can launch such components, commonly found in /system/apps
, like this:
launch spinning_square_view
Source code for Mozart example apps is here.
When you launch something that uses Mozart, uses hardware-accelerated graphics, or if you build the default package (which will boot into the Fuchsia System UI), Fuchsia will enter “graphics mode”, which will not display any of the text shells. In order to use the text shell, you will need to enter “console mode” by pressing Alt-Escape. In console mode, Alt-Tab will have the behavior described in the previous section, and pressing Alt-Escape again will take you back to the graphical shell.
If you would like to use a text shell inside a terminal emulator from within the graphical shell you can launch the term by selecting the “Ask Anything” box and typing moterm
Running tests
Compiled test binaries are installed in /pkgfs/packages/
. You can run a test by invoking it in the terminal. E.g.
/pkgfs/packages/ledger_tests/0/test/ledger_unittests
If you want to leave Fuchsia running and recompile and re-run a test, run Fuchsia with networking enabled in one terminal, then in another terminal, run:
fx run-test <test name> [<test args>]
You may wish to peruse the testing FAQ.
Contribute changes
- See CONTRIBUTING.md.
