Fuchsia Telephony
The Fuchsia Telephony stack currently aims to provide a fast, robust, and reliable
data connection over modern cellular protocols.
Source code:
Supported Hardware:
  • Sierra Wireless EM7565
Acronyms:
  • FRIL - Fuchsia Radio Interface Layer
  • VFS - Virtual File System
Getting Started
Setup
Telephony is not included in the core fuchsia bringup currently. You can include the bundle like in the
example below:
$ fx set2 core.x64 --with //src/connectivity/telephony/
API Examples
TODO(bwb): write an example app
Tools
See the telephony/tools directory for the source code.
ril-ctl
The ril-ctl package is used for interacting with devices that expose the FRIL interface.
Interactive CLIs are currently incompatible with the standard run command, so these are launched
through /bin
connection owned by telephony service:
$ ril-ctl
exclusive connection to device:
$ ril-ctl -d /dev/class/qmi-transport/000
Running Tests
Host Side Tests
A large chunk of the logic of interacting with QMI based modems is generated at compile time.
Tests for this live in qmigen_unittests_lib_test. You can run them on your host system with:
$ fx run-host-tests qmigen_unittests_lib_test
Unit Tets
TODO(bwb): Add name of tests when they land
Architecture
QMI-based
Modem Manager watches the VFS for the qmi-usb-transport device to bind against any of the
usb devices it supports. Modem manager uses an IOCTL call (TODO: transition to FIDL) to acquire
a transport channel to the driver. It then starts a service that provides the FRIL, ril-qmi. ril-qmi
proxies/translates the FIDL messages spoken to the RadioInterfaceLayer interface to vendor specific calls.
ril-ctl tool is also able to initialize and connect ril-qmi to a specified device. It will also eventually
have the ability to interact with an existing ril-qmi through a management interface on the Modem Manager.
                                |     Modem Manager    +-+---+
                                |                      | |   | vfs-watcher
     |     ril-ctl     |                   |             |   |
              +-----------------|       ril-qmi        +-+   |
                  Device Manager           |                 |
                               |    qmi-usb-transport  +-----+
