Fuchsia Boot Sequence
This document describes the boot sequence for Fuchsia from the time the Zircon layer hands control over to the Garnet layer. This document is a work in progress that will need to be extended as we bring up more of the system.
Layer 1: appmgr
appmgr
's job is to host the environment tree and help create processes in these environments. Processes created by appmgr
have an zx::channel
back to their environment, which lets them create other processes in their environment and to create nested environments.
At startup, appmgr
creates an empty root environment and creates the initial apps listed in /system/data/appmgr/initial.config
in that environment. Typically, these applications create environments nested directly in the root environment. The default configuration contains one initial app: bootstrap
Layer 2: sysmgr
sysmgr
's job is to create the boot environment and create a number of initial components in the boot environment.
The services that sysmgr
offers in the boot environment are not provided by bootstrap itself. Instead, when sysmgr
receives a request for a service for the first time, sysmgr
lazily creates the appropriate app to implement that service and routes the request to that app. The table of which components implement which services is contained in the /system/data/bootstrap/services.config
file. Subsequent requests for the same service are routed to the already running app. If the app terminates, sysmgr
will start it again the next time it receives a request for a service implemented by that app.
sysmgr
also runs a number of components in the boot environment at startup. The list of components to run at startup is contained in the /system/data/bootstrap/apps.config
file.
Layer 3: basemgr
basemgr
's job is to setup the interactive flow for user login and user management.
It first gets access to the root view of the system, starts up Device Shell and draws the Device Shell UI in the root view starting the interactive flow. It also manages a user database that is exposed to Device Shell via the User Provider FIDL API.
This API allows the Device Shell to add a new user, delete an existing user, enumerate all existing users and login as an existing user or in incognito mode.
Adding a new user is done using an Account Manager service that can talk to an identity provider to get an id token to access the user’s Ledger.
Logging-in as an existing user starts an instance of sessionmgr
with that user’s id token and with a namespace that is mapped within and managed by basemgr
's namespace.
Logging-in as a guest user (in incognito mode) starts an instance of sessionmgr
but without an id token and a temporary namespace.
