Fuchsia代码工具 jiri 问题???
8.7G代码下载后解压完,需要用到 jiri 代码管理工具,这个工具只能通过网络获取:
终端输入:
curl -s https://raw.githubusercontent.com/fuchsia-mirror/jiri/master/scripts/bootstrap_jiri | bash -s “$MY_ROOT”
后出现以下错误:
curl: (7) Failed to connect to fuchsia.googlesource.com port 443: Operation timed out
Cannot find prebuilt Jiri binary.
然后按照qq群网友 "毒蛇1983"找到的镜像地址:
curl -s https://raw.githubusercontent.com/vanadium/go.jiri/master/scripts/bootstrap_jiri | bash -s “$MY_ROOT”
安装成功,但在最后升级操作还是端口443错误:
‘git clone https://vanadium.googlesource.com/manifest /var/folders/s0/3_0x77ln1zjgxt33yn6kd0xh0000gn/T/jiri-load977930941/manifest_8f9c1ad9412dceb0’ failed:
Cloning into ‘/var/folders/s0/3_0x77ln1zjgxt33yn6kd0xh0000gn/T/jiri-load977930941/manifest_8f9c1ad9412dceb0’…
fatal: unable to access ‘https://vanadium.googlesource.com/manifest/’: Failed to connect to vanadium.googlesource.com port 443: Operation timed out
ERROR: Failed 1 times in a row. Last error:
qq群网友 "稀饭~~~“说: 443端口必须验证证书的
qq群网友 “毒蛇1983” 在后边讨论说:curl 7 443port,是终端代理问题
也搞不清楚到底是哪里的问题了,希望有大佬们能帮助下查查是什么问题,怎么解决?
你试试ping一下 googlesource.com
有可能是你没有过桥的原因
在群里我说了应该是没有过桥的原因~~~
最好改一下词语。。最近查的挺严的= =
之前我遇到过,在终端添加代理就可以了:
export http_proxy=xx.xx.xx.xx
export https_proxy=xx.xx.xx.xx
